I would like to ask you if for my QU SB is possible to have for a second scene a different in-ear mix or the in-ear mix applies globally regardless of the scene I am using.
Open the scene you want to use as the basis. Make the changes in the in-ear mix and then save it under a different scene-name ?
Giga
You can also safe and or block the scene functions that you do not want to change except the IEM mix sends levels.
Thank you Mike C. The idea is to have 2 different saved scenez with 2 different saved in-ear mixes.
Scene 1 - inputs mix 1 presaved - in ear mix 1 presaved
Scene 2 - inputs mix 1 presaved - in ear mix 2 presaved
So, when I switch between scenes, to have different in ear mixes I presaved
I think Giga’s explanation from above might do
I will try
Thank you both of you!
