Qu-SB New User Basic Questions
Hello Everyone,
I sing in a band and I also run our sound (sometimes), and I am a relatively new and inexperienced user of the Qu-SB Digital Mixer. I am hoping to ask occasional questions, and get occasional answers! So here goes…
When I am changing a monitor mix for one of our musicians, the main output changes. So for example if I add gain to the bass for the bass player to hear, the main mix bass gain increases also. I am likely doing something wrong, so this may be a simple answer. Another example is… if the same bass player wants more of the lead vocals in his (in-ear) monitor, when I adjust for his mix, the house lead vocal volume changes as well. Is there a simple way to change the individual monitor mix, while NOT changing the house mix? Thank you!
Do you come from an analog console ?
Giga
No I have only used the QU-SB
It sounds like you adjusting the channel input gains.
On the QU Pad APP you need to select from the mixes located on the
lower right hand side of the iPad screen, when you do that the faders
become the the mix send levels, like the aux knob on an analog mixer.
Remember to switch back to the main LR mix.
You’ll want the monitor mixes to be set for PRE FADE and generally set for
PRE EQ.
https://www.youtube.com/results?search_query=allen+heath+qu-sb+basic
Thank you!!!
Is there a particular way to set the monitors to pre-fade?
