I didn’t check but Is the default setting for the Q Drive (USB multitracking) post-preamp? Stupid question but is this just set on the global channel from any input channel?
Does post-preamp mean after the gain stage has been set for each channel but before everything else?
I would I Imagine this is the most popular way of recording, post preamp?
Also, in regards to the mix outputs would the most popular way to set this up as POST-ALL? So you hear eq and compression changes in your in ear monitors ect.
Post-preamp and it is a global setting that can be done from any input
channel.
It’s right after the gain stage.
Generally you’ll want to turn the follow fader option off.
As for mix sends it’s kind of a personal thing if you want to hear the channel
processing in you monitors or IEM’s.
Not sure I would want compression.
If you have the channel space you could split some of the key channels and use one for the mains and the other for monitors then could could EQ, compress, ect, just for the IEM’s using the second channel.
