Hi all,
I’m very pleased to let you know that V1.2 firmware is now available for Qu-5 / Qu-5D / Qu-6 / Qu-6D / Qu-7 / Qu-7D mixers.
You can find info and download links here - https://www.allen-heath.com/qu-v1-2/
Enjoy!
Hi all,
Enjoy!
This is honestly an incredible feature jump for this console. Well done and thank you to the team for delivering increasingly powerful tools for a desk that already represented top value-performance.
Kudos Keith and team. Sounds like a commendable jump up in abilities. Look forward to updating my Qu-5 today.
Happy Tuesday folks.
Yay…32x32 Dante available (wish it wasn’t paid, but at least it’s an option now) but also the windows/mac apps finally, and some nice other little features. Good update!
What a pleasant surprise! I spent an hour this morning updating my iPad to iPadOS 27, fetching the updated Qu-MixPad for the tablet and installing the new app on the Windows PC.
Everything works well!
I love being able to save a local copy of the show without moving the Qu’s external disk to my PC.
I still need MixPad on my iPhone, but it’s A&H apps everywhere else.
I really like the listen bus. I will use that with my small monitors (physically separate from the mains) rather than a separate mix; that’ll be a better match for my needs.
Y’know, I buy kit based on its capabilities at time of purchase; I tend to discount vendors’ promises because they’re usually unfulfilled. My Qu-5 just keeps getting better. ![]()
My heartfelt thanks to the folks responsible for making all this happen.
Update for iPad Air 5, Android phone, and Qu-5 itself worked flawless. Saw the expander, but forgot to look at the listen bus.
The iPad app now looks like the fader meter scale is edited.
Looks like a great update folks.
I see in the release notes for 1.2.0 there have been some tweaks to the SLink port as well.
Does this fix the problem I encountered when trying to connect a Qu-5 through a managed switch (Netgear M4250) to an AR2412? I did the original configuration and testing with an SQ-5 and AR2412, but once the Qu-5 arrived it didn’t work (it’s fine without the switch). I guess all SLink ports are not the same.
I would try the new firmware myself, but the QU-16 is at an install 150 km away.
Geoff
Hi, I had a weird problem today with the v1.2 ! My set-up is a bit different : I’m using a Qu-5D with an AR2412 over DSnake and sending matrixes + L/R via Dante to a mixrack routed to my PAs. As soon as I connected an RJ45 on the ethernet port (for Qu-mixpad), the sound experienced some glitches. I thought it was a bug with the dante port (looked like the output mixes going to my AR2412 weren’t affected but didn’t have the time to check) but it might actually be the Slink that had the problem. As soon as I disconnected the RJ from the ethernet port everything back to normal… weird.
Gonna check tomorrow if it really was the Dante port or the Slink.
Did someone experience the same bug ?
Just did the update and installed MixPad an the PC. I’m very happy to see, that the update isn’t just fixing an error but adding some functionality!
Also the Mix Pad on PC is great. I used MixingStation on PC, but it’s nice to have the same working steps on the app like on the desk.
Some things i don’t understand / don’t work as expected:
And there are som questions:
Is it possible to access Soft Key 9 to 16 on the Qu5 directly?
To access the function of DCA-Spill, do i have to use the Soft Keys, or is there another way?
The user guide is updated and answers a lot of your questions, so it’s worth reading through. The Expander is a Library preset that can be recalled - works very well.
The red on the LR button means it is in Listen Bus to fader mode, so this is trimming the output of the Listen Bus.
The DCA Spill is triggered from soft keys, yes. You can either spill a specified DCA, or just have one user button enabling ‘spill on select’, which I find is ideal for my workflow.
Oh, thank you very much. I’ll read the instructions, even though your reply has almost made it unnecessary ![]()
So, after reading in the updated user guide, a lot of questions are answered.
What is still open:
I totally overlooked the DCA Spill ‘on select’, because it’s at the end of the list. It’s the only one i need ![]()
Does others have problems with ‘Mix Select’ on Soft Keys?
The LR mix button being red means you’ve activated the PAFL fader to on. This takes over the normal LR 2 but Master fader and makes it control Listen Bus output instead.
When at the Gate tab, if you want the Expander, hit the Library button and load the factory Expander. After your edits, you can save a user Expander preset.
an expander.. yaaaaaaaasss!! thanks A&H!
Possible bugs in Qu Mixpad 1.2 (1.2.0.101579) on Windows 11 pro 25H2 (build 26200.9711)
on firmware 1.2.0 r4093 - but maybe someone can provide some insight.
(11.2.26 my update here fixes 1 issue)
App 1.2.0.101579 left the console firmware at 1.2.0 r4093.
I wasn’t aware the app would leave the console a bit behind on firmware vs the latest version available.
I found a newer firmware on the A&H website and manually updated to slightly newer firmware using a USB drive.
The console now reports firmware 1.2.1 r4106 and that took care of the QU-drive select file for playback showing each USB WAV file multiple times of 2 -5x each.
(Original questions below)
That’s great that they finally published the windows version.
It installed without issue. however,
(THIS 1st ONE below is now FIXED)
The Stereo playback page at UTILITY > Playback /Select Track shows each WAV file 2 or 5x.
(solution, that was caused by firmware 1.2.0 r4093 combined with Qu Mixpad 1.2 (1.2.0.101579)
For example, on a USB drive with 3 wave files:
Song 1.wav
Song 2.wav
Song 3.wav
the file selection window shows far more:
Song 1.wav
Song 2.wav
Song 3.wav
Song 1.wav
Song 2.wav
Song 3.wav
etc
Next question:* Firmware notes says:*
"ID-901 - USB files now date/time stamped when Qu MixPad app device connected"
Does it show that info somewhere when selecting USB files?
I only see file names shown, the same as before. No time or date info.
Photo attached. Is that shown somewhere other than on the console or in the app?
{Last item}
The keyboard arrows have no effect when selecting Up/Down on various parameters or selecting a playback track. It seems to respond to the mouse, but not a keyboard. (unlike most windows programs).
That’s not required but would make it more full featured if the keyboard worked which is usually how programs work on Windows. Imagine having no keyboard, that seems to be how it’s setup.
That would also help nudging some settings that like to jump when trying to use a touchpad on a tiny target.
Anyone else notice the quiet 1.2.1 release with a couple more bug fixes?
“the quiet 1.2.1 release” - yes, really! I wouldn’t be angry to receive a mail for any firmware update…
The 1.2.1 solves exactly the problems i had with 1.2.0. It’s worth to stay updated, so why not spreading the news?
Another thing they solved: The touchscreen follows now the changings you do with the EQ-knobs (you change band 2 - band 2 get selected and you see the values changing in the screen). Very helpful!
In my eyes with 1.2.1 the version 1.2.0 is completed and my QU5 makes me even happier then before.
