QU24 and AR2412 + Speaker setup
Hi, this may sound like a silly question but wanted to ask anyway. I am doing a portable setup for an very small event. I have the following
QU24 mixer
AR2412 dsnake
Mackie Speakers.
I am looking to minimise the amount of wires to the stage from the desk so I was planning to just run a single ethernet cable to the dsnake and then run all the wires from the dsnake, when I realised I need output for the speakers. What I am wondering is can the main L+R output be sent to the dsnake so I can hook the speakers straight to the dsnake.
Hope this makes sense
Regards
Ash
Yes
By default (I think) L+R will be outputs 11 & 12
And Mix 1 = Output 1, Mix 2 = Output 2 >>>>>>> Mix 10 = Output 10
You can change what you send & to where in the routing section.
As Mark said.
We do this all the time on live shows and I’ve done many installs. One CAT cable to stage area. Inputs as normal. Then outputs to powered speakers or amplifiers. Go to I/O patch if you need to change anything. You can see on there what outputs appear at what sockets.
As above is correct - default isnoutput 11/12. That’s how I run every time
