QU24 Changing slider on one mic changes for all mixes
On my QU-24, if I set slider 9 to a certain level, say for LR, that same level gets set for all other mixes including Mix 1, 2, 3, 4, 5-6, 7-8, and 9-10. If switch to one of those mixes then change slider 9, that new level is assigned to all other mixes. This only happens with slider 9. Is this a setting I can change, or a defective slider?
Sounds like a pre fade / post fade setting.
Mixes set for post fade will change as the main LR mix levels are changed.
Mike, thank you. Can you tell me where that is set? I’m looking over all 20 channels that feed Mix 9-10 and I can’t see where channel 9 is set differently.
Select ch.9 and then select the routing page menu or select a mix
and then hold the PRE button on the Left of mixer, the channel’s SEL buttons
will light up if they are set to PRE FADE. to select POST FADE keep holding the
PRE button and press the channel’s SEL button. When the SEL button light is off
it is POST FADE.
