Qu24 mix send Compressor not working
How do I get the mix sends to include the compressor? Eq and gate work fine. I am using mix 5/6 output.
Hi Ppajko1,
To change the channel source for the mix, press the Sel key for Mix 5-6, then press the Routing key to view the Mix Send settings. The Channel Source is set to Post EQ by default, but can be changed to Post-All to include the compressor.
Alex
Worked…thank you so much!
