Hi guys,
I have a QU24 mixer which has not liked the Firmware 1.7 update when used with v1.6 show files…
The firmware went in fine, and I updated my iPad to the new App to.
All worked fine.
Then I loaded a show file in which was from v1.6.
Playing back from the QU drive some audio channels disappeared.
On further investigation, Ch’s 1, 3 7 and 8 just had no audio.
Switching over to the local input with a microphone, they had no audio either…
I did a hard reset and the channels worked directly and also from the Qu drive.
Again i loaded in a v1.6 show file, a different one this time and the channels stopped working again.
Another hard reset, save a v1.7 show file and reloaded, worked fine.
reloaded a v1.6 show file and ch’s stopped working.
Tried reloading the good v1.7 show file but the channels still did not work. adding to the fact ch 9 now stopped.
I reloaded the v1.6 firmware back into the QU24 and all channels worked even after loading the v1.6 show file that killed the channels in v1.7.
It would seem there is a problem of compatibility between v1.6 and v1.7 show files…
As I have upgraded the iPad to the new app, I imagine its hard to revert to the previous one.
As the new app isn’t compatible with v1.6 firmware…
I can no longer use the iPad with the desk.
My only choice it seems is to reload v1.7 and make new show files from scratch…
Not the best way as there are a lot of things set for the band I work with.
Anyone else tried, tested the above? I am just hoping it’s not just my desk…
