QU32 AR84 dropping out?
In the middle of huge 3 day event.
Suddenly the AR84 just drops out.
Using 50 metre cat 5E (not A&H)
Only way to get the QU32 to see the AR84 is to restart the QU32
Happened 3 times in the middle of sessions.
I nearly suspect it is when I go to look at GEQ in subgroups?
However so inconsistent and happened 4 times over 2 days so far.
The AR2408 stays in sync ok
If any one has any ideas please advise.
I have an 15 hour show tomorrow … that’s a start time of 6 hours away
cheers
thankyou
dave NZ
when you say “drops out” do you mean the control, audio or both? how often did it happen? it might be worth testing it on a short run of cable to eliminate the 50 metre run you have, and trying a different link cable. also check that your mains and mains cabling is okay, i’d imagine a brownout or intermittent supply could cause problems.
Contellation is Qu32->50mCable->AR2408->ShortCable->AR84, right? If the AR2408 stays in sync I’d check the expansion connection first.
Thanks for somments
I have to go back to event now.
QU32 stays in sync fine over 50 meter cable. The AR08 has short A&H link to AR2408
Running UPS no problem there…
Generator power which is very stable.
I’ll change the short both cat 5E cables to the AR2408 and AR08 this morning
I nearly suspect it is loosening sync when I go into the menu of the QU32 which is a scary thought as I need to do that to tweak Group GEQ.
and today we will be doing a lot of recalls …
anyhow thanks
with out dropping in major conponments.
My monitor engineer suggested we run an analogue multicore…
ahhh I dont think so!
keep you posted.
I have a long day and night ahead’'cheers
swapped AR2408 with new unit and it ran fab all day and night.
No drop outs.
thanks all
dave NZ
