Just trying to hunt around for instructions on how to assign a particular “Microphone Pre-set” to a specific channel…?
Can’t seem to find a ref. for this option. I have a combo of Sennheiser and Shure top end mics for Vox, Drums, Guitars etc…
and would like to mix it up a little. I understand completely the use of the pre-set as a “Starting Point” which is all I’m wanting to use them for. I can tweak from there.
Any clues on this? I go into the library’s and choose accordingly, but it appears that it makes global changes to VOX channel library.
Included with the ProFactory Preset downloads here - https://www.allen-heath.com/profactory-presets/ - you will find a PDF which gives more detail on the presets as well as a guide on transferring them to and recalling them in your Qu.
I’m not sure what you mean by them making global changes to VOX channel library, but if you open the library from the PEQ screen on the channel you wish to apply the preset to, you will see two lists.
The PEQ library will recall only PEQ parameters and the channel library will recall a whole channel (with or without preamp parameters).
Hi Keith
Thanks for your reply mate, I actually think it’s ok now, I’ve just come from the music room
and I reckon it’s sorted ? solved it in-conjunction with your A & H YouTube video on presets ?
