Conceptualmente la consola,es el alma de cualquier equipo de sonido,ya sea para una aplicacion de estudio,directo etc.En nuestra empresa tenemos una ilive T-112 con su IDR-48.Hasta ahora todo son satisfaciones, sus previos,sencillez y rapidez a la hora de operar. Pero no tenemos una fuente de alimentacion externa ( CPU )y el IDR48 no esta preparado para adaptarla.Que hacemos en caso de fallo de su fuente? A MI CONSOLA LE FALTA UNA SEGUNDA FUENTE DE ALIMENTACION.
Maybe you should post in english?
And for those of us who dont read Spanish…
Conceptually the console, is the soul of any sound equipment, whether for an application of studio, live etc.
in our company we have a ilive T-112 with IDR-48 Its previous simplicity and speed when operating.
But we have no external power supply and IDR48 not prepared to adapt it. What to do in case of failure of its source?
MY SECOND CONSOLE LACKS POWER SUPPLY.
Answer - buy the mod kit to change the backpanel of the IDR48.
GW
Or have great faith GW [ ]
For all those interested, the Dyson DC25 vacuum cleaner actually uses the same power supply and DSP as the IDR48.
https://www.dyson.com/store/product.asp?product=DC25-BLUEPRINT
Although those who have so far added this as an upgrade say the sound now sucks.
buenas noches albin,lo siento pero me cuesta mucho expresarme en ingles,imaginate escribirlo
Buenas noches Grahamwihite,me informare con mi distribuidor, he vendido una y LIVE T80 aun centro de formacion de sonido y IDR-32 viene con esa mejora que comentas en el panel trasero.AHHHHH… MUY BUENA ESA TRADUCCION FELICIDADES!
Sr.B estoy en barcelona acabo de llegar al hotel de un bolo con unas 4000 personas,y todo perfecto con la ILIVE T-112 ahora creo en la fe que dices jejeeee
Wow GW the Dyson looks good value and possibly cheaper than a spare PSU, maybe it would help keep FOH position clean and tidy like.[:o)]
It is so nice when a serious forum like this one provide so much assistance to the masses. TTFN
YEP AND DYSON MIGHT ADD DA VITAGE NOISE!!!
cheers
dave
allen&heath iLive-144 /idr 10 /
Might well be the answer to DiGico’s Vacuum tube pre-amps!
Cheers,
Marc
Could it also rival the digidesign Plug In idea?
Possibly a bit like an aural exciter, to add a little extra “air” to a mix, just when you need a little extra Whoosh[8D]
i have this one poti wich is scratchy (probably dirty) i need urgently a plugin to assign the noise (prefearably a broken neve 8101
pan pot scratch with random dropouts)[ ]
here it comes chaps!!(watch me now)talking bout vintage:
preset called: Harrison 32c Audio Console (other consoles will be build on request as they are using different hardware)
needed parameters:
condenser dryness (set last full recap date / to be able to set the “how old is da locomtive”)
fader scratchness (from standard hamburger finger grease up to total cola stickyness)
bantam patchbay depression (from normal to suicidal annoyance,deep red led please)
smpte bleedin through whole console (selectable bleeding source either channel 1 or 24)
ground (mass) on off (aux potis dont find no zero no mo)big fun with sae newbies…
ribbon cable assembly musher (connect everything wrong (only with admin rights))
last but not least xlr corrosioness.
cheers
dave
