When selecting “when” the Direct Out signal is taken from a channel, are there any consequences to the signal if later stage processing is NOT engaged.
I’m referencing section 8.1 on page 36 of the SQ Reference Guide (for the SQ-6).
For example, should I expect to get a digitally IDENTICAL signal at the direct out if I selected “Post Preamp” and then later “Post Comp” if all High Pass, Gate, Insert, EQ and Compressor settings are set to ‘off’, and the follow-fader setting is also turned off?
