Hello,
I’m considering buying an SQ system (either 5 or 6)
My principal use will be for live sound, but a home studio control surface is a nice addition. -I have some questions that I really need answering before I purchase this (to help me to decide the model I will buy.) (I think either SQ5+AB16/8, or SQ6 but no snake.)
I have a few questions.
1, 16 inputs is “not enough” for me, (so assuming I get the SQ5 + snake, which only has 16 channel faders.)
How easy is it to move between “fader pages” when changing channel volume? - Is it intuitive to press a button to transform channel strips 1 - 16 into ch 17 - 32? - I assume that I can press a button and have all the faders move etc. (I hope it is clear what I mean. - I don’t quite understand if this is what is meant by “layers” on the website.
2, I’m used to a 24 ch (analog) desk, with 4 stereo sub groups. - this has become integral to the way that I mix some bands where I may have mixed a section onto a bus…
what I mean is I have Brass in channels 1 - 4, routed to subgroup 1 only (not main mix), and drums in 5 - 12 routed to group 3 (but not the main mix) then I route the output of group 1 to the main mix and the out put of group 2 to the main mix.
once I’ve mixed a section I may want to “push brass”, or bring up “drums - all drums” then I’m just bringing up an already balanced sub group etc moving 2, instead of 12 faders.)
- can I assign, the fader board to mimic this, so that (on an SQ 5) faders 1 - 12 are assigned to channels, and 13 - 16 are assigned to let me adjust group/aux levels. (and can I assign these sub groups/auxes straight to the main bus?)
- is it possible to assign rotary knobs for this subgroup volume? (-if I wanted to assign rotaries for group volumes I guess i need SQ6 since SQ5 does not have these?)
Final question.
Sometimes I want to record gigs. - currently I’m doing that with a 24 channel ADAT. however I want to use the SQ Drive… I know that there are 16 inputs, or stereo from master bus.
What I want to know is:
is it possible to record a mixed group to a single channel on an SQ drive?
I mean can I have a channel as snare batter head mic and another as snare response head mic, mix those at the gig to a sub/aux group, and then record than sub group to a channel on the sq Drive? (I know I can’t change the balance between top and bottom heads later if they are on a single channel of course.)
(I guess my question is, how flexible is the routing matrix when it come to routing to the 16 recording channels on SQ drive?)
I know that 16 channels is less than I’m used to for recording - so can I finalize some choices to a mixed channel at a gig and record that? rather than waste recording inputs with something that I won’t need to have a separate stem for later?
(the alternative is bringing a PC to a gig and recording straight to that with the 32 channel record bus over USB, but I’d rather take a USB disk than a computer.)
Hey to your questions … is it the first contact with digital desks ?
How easy is it to move between “fader pages” when changing channel volume? – Is it intuitive to press a button to transform channel strips 1 – 16 into ch 17 – 32? – I assume that I can press a button and have all the faders move etc. (I hope it is clear what I mean. – I don’t quite understand if this is what is meant by “layers” on the website.
It´s easy to switch and yes all faders move automatically, the good thing is that you can create your own layers and perhaps a stereo channel is also only one fader, I normaly work with 32 channels for my band (means two layer) and create a third layer with only the VIP channels
2, I’m used to a 24 ch (analog) desk, with 4 stereo sub groups. – this has become integral to the way that I mix some bands where I may have mixed a section onto a bus…
what I mean is I have Brass in channels 1 – 4, routed to subgroup 1 only (not main mix), and drums in 5 – 12 routed to group 3 (but not the main mix) then I route the output of group 1 to the main mix and the out put of group 2 to the main mix.
once I’ve mixed a section I may want to “push brass”, or bring up “drums – all drums” then I’m just bringing up an already balanced sub group etc moving 2, instead of 12 faders.)
– can I assign, the fader board to mimic this, so that (on an SQ 5) faders 1 – 12 are assigned to channels, and 13 – 16 are assigned to let me adjust group/aux levels. (and can I assign these sub groups/auxes straight to the main bus?)
– is it possible to assign rotary knobs for this subgroup volume? (-if I wanted to assign rotaries for group volumes I guess i need SQ6 since SQ5 does not have these?)
Yes can do all of this, every subgroup use one bus - if you work with to stereo/mono subgroups you have 10 aux free + 4 effects, and yes you can put a subgroup on a layer (if you use a sq5) but also rotary knob (only sq6)
Final question.
Sometimes I want to record gigs. – currently I’m doing that with a 24 channel ADAT. however I want to use the SQ Drive… I know that there are 16 inputs, or stereo from master bus.
Yes that is possible, you had to confige that much subgroups and they are going from you amount of busses/strong>
I know that 16 channels is less than I’m used to for recording – so can I finalize some choices to a mixed channel at a gig and record that? rather than waste recording inputs with something that I won’t need to have a separate stem for later?
Awesome, thank you very much.
Hi Danny - I just noticed that you are looking to dive in and get an SQ.
I have an SQ-7 for sale (topic in the SQ forum on here), could make you a good price. The SQ-7 is only slightly larger than the SQ-6.
I am upgrading mine to a DLive - I bought my SQ-7 in Jan this year - had only studio time since/never gigged/pretty much mint.
Tx,
Peter
Unfortunately I bought an SQ5 before I saw this, but many thanks for the offer.
