QuPac: Multichannel record "dry" + L+R "wet" ??
For post editing I want evrything separated and dry but is there a way to, at the same time, record
master out L+R post everything (with EQ and effects)??
I always end up in the global USB streaming settings (for pre/post) and can’t se if and how this can
be done. With so many ways of doing things with routings etc. I’m lost…
Hi Gazza,
With the default settings this should be set up already! Inputs 1-16 and 19-32 are set to record the input channels, and 17 & 18 record the LR bus.
To configure which channels are recorded, you can access this in Setup > I/O Patch > USB Audio.
Alex
