hi i want to buy a surface for use with idr32 - is it the right joice?
most jobs i do are 24 ch
what do you think?
thanks for your replay
regards joefi
iDR32 + IPad1 + Laptop
*** less is more ***
what do you think?
regards joefi
R72 is OK but if you are mixing bands with more than 6 monitor mixes it can be a bit painful. Also jumping between all the banks seems to take forever when things start to go wrong. If I’m working a live band I’ll often end up building a layer with a mix of DCA’s and vocal inputs to I can try to run the show on one layer. Lazy but it works for me!
The R72 is nice and small though so it tends to go with me if I think I’ll be running a show off editor as its nice to have a physical fader to pull when it all goes wrong. Great for corporate & AV style jobs for the same reasons.
Don’t try doing a 16 way monitor mix on it though!
hi joefi,
I think it’s not only a question of channel count, but more a question of workflow and mix requirements, complexity.
Questions to think about are:
How many channels do you need to have under visual control at a time?
Do you feel fine while swapping through layers all the time?
Do you mix foh and monitors on the desk?
How many effects are to be under direct access at a time?
How is your workspace on the jobs, does it fit for a T112 or is it cramed after setting up your PC?
Personally I like the the R72 very well as it comes in a slim design, efficient, well designed and you need no additional hands for transport.
Give me a call if you like to get more ideas about my experiences.
br Gunter
Günter Eisbach
dL-Recording
Darmstadt / Germany
hi guys,
thanks for your fast reply and informations!
soon i will add a R72
kind regards
joe
I have an R72. It’s a shame the left bank of faders is only 8 wide and
I think the Eq should be on the surface too. But all in all I love it. It’s small and
Easy to use. Most of my shows are 16 inputs so it’s not to hard to keep
Track of where you are. I always have inputs on the left and mixes on the right bank.
Jim
R72 & IDR32
MacBook pro
iPad 2
Airport express router
quote:
Originally posted by jimvoyagerI have an R72. It’s a shame the left bank of faders is only 8 wide and
Jim, you should have bought the T80 surface instead [
I have a R72 also and use it a lot. But mostly when i mix myself. its not that easy for a BE. i wished that there were 16 user buttons/maybe some user encoders.I use all the 8 buttons as mon-mix send on faders. I rather use my T112 when there is a visiting BE.
Kind regards.
Lieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver
I dont mind the r72 one but.
Yeah jumping pages can suck. For the size it does so much.
I run DCA on the last page and usually just mix from there for the show.
I have run festivals with 6 bands plus on this board and also monitors from this board. No problems. W
I think we are all spoiled by the big boards but this thing is fantastic.
Honestly though i would like a t80, even then i think i would still EQ from touch screen and a rotary knob ![]()
Hmm…it must be broke!
