Random question, currently our broadcast feed is handled by an Aux output, but we want to buy a separate SQ mixer for it. The only problem is that the built in Slink port is handling DX168 stage box duties, and the Slink I/O card is handling ME1’s. So I really don’t know where I would be able to plug in that broadcast board. And yes, dante would fix all of this but switching over to DT168 from DX168 would be a huge pain!
My first approach would be to either connect the DX-Boxes to the broadcast console (disadvantage is that then the input gain is controlled by the broadcast console) connect the ME1 to the broadcast console. You can use tie lines to forward the source signals to the indented targets. Pro is that it can be solved without extra cost (maybe some extra network cables are needed for the different connections).
The first, trade the dx168 in for an gx4816, the gx4816 has an me port, so you can connect the me’s to the gx, the 2nd sling is then available for split.
The second option to put an slink card in the broadcast sq and connect the me’s to the broadcast sq.
The third option, buy and dline cdm32 with c1500 and gigaace card. Now you can connect every thing to the cdm32.
The forth option to replace the dx168 boxes for an ar2412 with ar84, then you can also connect the me system to the stagebox.
The are enough option, is only depends on money i’am afraid.
Not sure if this is possible. Maybe someone from A&H could chime in here.
Couldn’t you get a DXhub, connect the DX168 to a DXlink port, the broadcast SQ to another DXlink port and the FOH mixer to uplink (gigaAce?) port?
oooooooo I like the idea of plugging in the ME-1’s to the broadcast board. We would probably have both boards on our power relay system so we don’t even have to go back there to turn it on! Those Slink cards aren’t that expensive either, the other tech guy keeps making fake fun of me for not getting dante cards haha.
