READ BEFORE UPDATE TO 1.4 (master fader not working)
Hey, if you plan to update to 1.4 please, save scene/show, after update, if your master fader is not working, well, it shows changes everywhere (in app, on screen etc), but doesn’t actually output any sound anymore, then do this:
  1. in Setup → mixer config Reset Mix to Standard
  2. Scenes → Scene Manager → Recall Filter → Mix TAB and under the Main section BLOCK processing, then recall your mix as usually.
This should save you some minutes. Huh, for me it almost ruined the event!!! ;p
Hi Fleck,
Could you please open a ticket at support.allen-heath.com so we can look into it further?
Alex
Yes, will do after event! I did not have time to investigate this, but I noticed one more problem. I Use Matrix 2 for PC recording audio from Main (LR mix), it does not work, Matrix 1 works, PAFL shows no signal on Matrix 2. Looks like Matrix 3 is also not working. But will look into it later today!
Yep - some updates - did the same for Matrixes for Recall Filter (blocked processing recall) and there is sound on ALL matrixes!
