Hi Folks
Using an SQ6
I am creating scenes for a virtual soundcheck and have a question regarding Preamp levels.
Scenario - Three scenes
- Live scene - main scene used for Multi-track recording as well thru USB-B to reaper on a computer.
- MT Playback I-O Scene - Select this scene after the MT recording is complete. I only want the I-O to change so everything else is blocked using a recall filter.
- Live I-O scene - Finished setting things up using the MT recording and want to set the I-O back so everything is blocked except the I-O again using a recall filter.
Observation
When I set the recall filter for either scene that just changes the I-O and block the Preamp but allow the Patch for Inputs, the inputs do not come in. I have to unblock the Preamp to get the input patching to come. in. There are no Global filters or Channel safes set, only using the recall filter. I tried this multiple times on the console but then tried it many times on SQ Mixpad with the same results.
What I would like to see
Step 1 - set the preamp gains when the band is on stage.
Step 2 - Select Playback scene to change the I-O so during playback from the DAW the preamp gains are already set and digital trim is 0 and wont need to be changed at this stage.
Step 3 - Any mixing/processing changes that need to be made based on the recording are made.
Step 4 - Select the Live I-O scene so the I-O is changed back and the preamps stay at their current levels, ready for the band to be live.
Questions
1 - Am I wrong in assuming I can keep the Preamp levels that were set during soundcheck thru the MT recording and then back to live? If so, some insight would be very welcome.
Comment - I know I can use input libraries but they do not affect the Output changes required and I want to be able to recall scenes thru Bitfocus companion on a tablet to make everything happen in a couple of buttons (Sets up reaper the directories and project files, selects the scene on the SQ, and has transport buttons for record and playback). I have this working well but still need to fiddle with the preamp gains at each stage - rehearsal, playback then Live. I don’t have a lot of experience with this, perhaps this is normal but I just find it awkward and perhaps I missed what is suppose to happen all together.
Thanks in advance for any thoughts.
Tom
