If you are looking for a way to recall iLive scenes wirelessly from your iPad, iPhone or Touch then check out the TCP/IP Remote app. This will directly send commands to the mixrack via wifi and can be used alongside Mixpad or Tweak
The app can be customized to control any supported iLive TCP/IP command - Faders, Mutes, preamp Gain, Pad, 48v, DCA assignments,main mix assign, Scene recall and even channel name & colour.
There’s another app called IPCodes which looks like it may do the same thing (but it’s only a $0.99 app!), have you checked that out? Thinking I’ll try Richard’s approach with that app this week… it’s not as pretty, but looks like it should achieve the same result. Cheap experiment if not!
Adam Biggs
iDR48 & IDR32 mixracks
MixPad for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless)
Windows 7 Pro 64bit
with Belkin PlayMax N600 HD router
Dante card tracking into Reaper with playback via FooBar
