Recall Libraries or Reassign Input
Looking for opinions here. I mix at a church. I’m a volunteer and most people here have probably forgotten more than I know. That said I’m here posting on a forum for advice so I’m not completely useless. So we rotate thru a few different artists week to week. Mics are routed thru stage boxes, d snake into desktop. I have different preamp settings, EQs, compressor, etc. for each artist.
My question is when I come in and Joe is on the mic that Sam was on last week would you leave the input alone and recall libraries for eq and other settings or would you have a channel dedicated to artist A and another one artist B then unassign/reassign the input to the correct channel whenever they change? What do you see as pros and cons of each option?
Sounds very similar to our setup: we have baseline settings for input gain/gates/filters/PEQ/Compression saved by name in the Avantis library for each vocalist/instrumental and whichever channel they end up on, we just reload their settings and we are 80% ready to go
You could set up a scene for each singer and filter down to only restoring the settings you want for just that one channel. Then just name the scene the persons name. If the singer was on a different channel than what they were when you created the scene, you could just repatch. Just a thought.
Thanks for the input.
