"recall" not 100% correct
i got a problem:
when i offline store a show in the editor, an later i load this show (over USB) in the surface, sometimes a gate or a lowcut parameter in some channel are not correct.
one time i had a different gain-parameter in channel A1!
have anyone made this discovery too?
(here is the “bad english service” from germany[:smile: ])
Hi Wolfgang,
I have been unable to recreate your issue. would your be able to send the show in question to: Support@allen-heath.com
Can you also provide a description of what parameters are incorrect when you recall the show on your desk? Also a description of your offline show hardware and your physical hardware setup.
Does the offline setup in Editor match the physical hardware setup you have? It is important that the offline session does match your physical system setup so that you do not have any compatibility issues that could cause parameters to be different.
Best Regards
Sam A&H
yes, the offline setup has the same setup as the hardware.
i have send my file to Markus Sinsel from A&H Germany.
