Record less than 18 channels?
Let’s say I only want to record 8 channels using the QU USB. Is there a way to record less than 18 channels.
It seems like a waste of disk space to always have to record 18.
Any help on this is appreciated.
THANKS,
AB
I wanna this feature too. Should be able to x it out.
I suppose this is your way of saying that I cannot do this now? What sayeth A&H people? Can I do this? Is this in the works for a firmware update. This is a serious issue.
THANKS,
AB
Although it is a waste of disc space when recording, the unused channels can be disposed of when importing into your computer for mixing down. Even using the QU for remixing, the same memory stick can be used, then used again once the project is over. Memory is relatively cheap.
If you archive all your multi tracks, I agree, it is a waste of memory and a firmware update to record fewer tracks would be useful.
It occurs to me that uprating the firmware a couple of times a year is a very good way to increase the usefulness of a product and keep it at the cutting edge using users suggestions without having to design a new product every few years from the ground up.
There are workarounds for just about any scenario but an elegant software solution is much more attractive. Until the CPU is gasping for breath and reliability is a problem.
Thanks for your help. If I do not stop the record, will it record hour after hour or does it have a time limit or GB limit?
If it has no GB limit, then I can use my 1 TB external drive, record for a good 3 to 4 hours and be in good shape.
THANKS,
AB
There is a time limit, because the FAT system has a ?2GB file size limit.
That’s plenty of hours though.
I couldn’t remember if it’s 2 or 4 either! Turns out it’s 4GB. This gives about 8 hours for multitrack.
All you need to know is here:
https://allen-heath.helpserve.com/Knowledgebase/Article/View/774/0/qu-drive--understanding-qu-drive-and-usb
I think it’s a 2TB partition size limit and a 4GB file limit.
I was wondering why they didn’t just do an 18 track wav (pretty sure the format supports it) and the answer is, of course, that we’d be limited to approximately 25 minutes per file. Of course a different file system would have had different limits, but that’s beyond the scope of this discussion.
I read in the QU-24 user manual that for multitrack recording you should use a USB HDD hard drive and not a USB key/stick??
I have a 32 GB USB stick.
I need to record a 30 minute maxworship service. So with a 8.64 MB/min = 259 MB = 0.26 GB. I reckon my stick should work for this small amount of multitrack recording? Would you agree?
Which stick. The issue is continuous write speed.
The forum recommendation in the Sandisk extreme.
…it is 8.6MB/min per track, so for 30 minutes with 18 Tracks you’ll get 4.6GBytes…
Anyway, as Bob said: Critical factor is a required continuous write speed of about 5MB/sec, not that many USB sticks can properly handle that. The Sandisk Extreme does it.
If this chart is true - it is not 4 gb for 18 tracks. It is 9 gbs for 18 tracks in an hour. If there is a 2 or 4gb file limit, do new files automatically get created and fit together or is there a gap? This could be a pain.
Mono
Formula:
Bits per sample x samples per second = bits per second / 8 = Bytes per second x 60 seconds = Bytes per minute x 60 minutes = Bytes per hour of mono.
Settings Bitrate File size
per second File size
File size
minute per hour
16 bit, 44.1 KHz 705.6 Kbps 88.2 KB 5.292 M 317.52 MB
16 bit, 48 KHz 768 Kbps 96 KB 5.750 MB 345.60 MB
24 bit, 48KHz 1,152 Kbps 144 KB 8.640 MB 518.40 MB
24 bit, 96KHz 2,304 Kbps 288 KB 17.280 MB 1.0368 GB
Stereo
The 18 tracks are all individual files, no ide what happens past the file size limit, but I guess bad things.
So I put in a 1 tb USD drive. It says about 8 hours of recording left. That is very good news. I am letting it run. I will see if it splits files or just makes really long ones!
9GB per hour = 4.5GB per half an hour, where’s the problem?
Recording hopefully simply stops without bad sideeffects. The Qu does not create a new bunch of files automatically.
A person would have to stop and start the mixer after every song or two in a live setting. That is the problem. As opposed to many other recording devices that make new files without losing information. That is why other recorders do that!
Nah, I record whole sets, if not gigs.
The file size limit is per track, so 8 hours at a time is OK
Thanks Bob. I just recorded a couple of hours and it was not an issue. I think it will be just fine. I did not hit the gig limit per file, so I wonder if it will stop at 2 gb per file?
Best,
AB
Like Bob above, I record 14 tracks of material (and 4 empty tracks) regularly on a SanDisk extreme. The gig starts at 9PM and grinds to a halt at around 11:30 PM. I don’t normally bother to stop recording at the break around halfway through the evening.
The manual for the QU 16 does not include the SanDisk Extreme memory sticks as suitable because they were not around at the time it was written, they work perfectly. The only warning I should give is that there are plenty of fake memory sticks out there so make sure you buy from a reputable dealer. The memory sticks are so much more reliable than the bog standard hard disks which can experience problems with vibration at high acoustic sound levels experienced on stage!
One more word of caution, it is possible to snag the memory stick with your headphone lead, I route mine around the back and bring it up on the left side of the mixer to avoid messing up the recording.
I use a uSB3 extension lead with a right angled connector to put the stick under the mixer.
