Record multitrack, how to record the 21st track,
hello experts,
how to record only the 21st track. i had recorded the stereo but the voice is very low and has ups and downs too in the audio…
You need to patch the USB outputs (under routing?)
thank you, could you please let me know how to achieve it?
Section 11.18 of the manual
https://www.allen-heath.com/key-series/qu-series/
Documents → mixer reference guide.
thank you i able to receord, however, when i play it in the computer it is very faint and not audible… sometimes it can be heard but not that loud. i had converted to 320 kpbs but still no luck .
P.S. I has set to Direct out as well.
any suggestions would be much appreciated.
Stick the track in a DAW of your choice (Audacity maybe if you don’t have one already?) then normalise it or run it through a compressor with high make up gain, or whatever sounds right to you.
Thank you Much Mark, that helped
