Recording Bluetooth Playback
Hi ,
Is there any way to record the bluetooth playback in Multitrack for CQ-18T.
In the channel assignment there is no option for BT to assign to any channel ?
Also what is the recommended settings for MAIN L/R for a Live band with multiple instruments and vocals ( is 0 DB or lower ) considering speaker volume is at 0 or -5 DB.It seems to be getting a lot of feedback when turning up the MAIN L/R to 0 DB.
Thanks ,
Bandboyz
I don’t think it is possible to record the BT channel as there are no outputs that you could re-route into another channel.
There are no recommended settings perse as all systems differ from one another. If you’re getting feedback you need to look at your stage monitors and speaker placement as well as your eq’s.
:slight_smile:
I don’t know if there’s a way to record the Bluetooth tracks separately, but BT will get recorded in the Main L/R mix if you include that in the multi track recording. Good feature req
If you have a spare stereo aux then send the bluetooth to that alone, then set the multitrack to record that Aux as one of the sources.
I don’t see a method to send BT playback to an input. That would be fine.
