Recording LR Post Fade on Qu-Drive Multitrack
Last week I tried to do a multitrack recording with Qu-Drive patching LR post fade to channel 17-18 using the Setup /
Audio / Output Patch screen.
After going through the recordings, it seems that it was still recording Stereo I on channel 17-18.
Anyone else experienced the same problem?
Did you remember to hit APPLY when you sel;ected the output source? They don’t tell you that you have to do that. Choose the option you want, hit apply before leaving the screen.
I also found out that the multitrack recording display does not show you the channel selection for 17/18 until you arm it to record - I like to record the pre-fade master, and I seleted it several time and it did not show, until I armed for recording and then it showed! Kinmd of lame, but okay once you know it.
I guess they will change this behavier in future software updates…
Thanks for your reply! I will check!
The Home->Qu-Drive->Multitrack screen managed playback and recording all in one screen with one set of meters and transport controls.
Since multitrack playback always sends Qu-Drive channels 17+18 to ST1 it has to reflect this when you’re stopped/paused/playing. Once you are armed/recording, it will show you the output patching which has been set up in the Setup screen.
Basically, the issue stems from the routing being fixed in one direction, but patch-able in the other direction. Hopefully that explains the behaviour you’ve been seeing. Apologies if this isn’t very intuitive, it’s something we could look at for future releases.
Regards,
John
A&H
Yes please
