Hi there
Is it possible to record ST1 ST2 ST3 to multitrack USB stick?
I’m only getting 18 tracks showing up on the USB stick when I record, Channels 1-16 then 17 & 18 as the stereo FOH mix.
Hi there
You need to change your USB routing map. Setup → Output Patch → USB Audio. Set the desired channels to ST1L ST1R ST2L ST2R ST3L ST3R etc as necessary
DC
Ah great, so I can record all the ST channels as well as all the Channels 1-16?
No - but you can choose which 18 channels to record.
You might need to down mix a couple, I think you can select mixes/groups to record, so you can dump e.g. the drums as a single channel.
OR:
Yes - but not at the same time.
The USB B recording option might also be of interest.
You need to change your USB routing map. Setup -> Output Patch -> USB Audio. Set the desired channels to ST1L ST1R ST2L ST2R ST3L ST3R etc as necessary
Hi
I cant see how to change what channels are recorded from the above. Can anyone help please?
Thanks in advance.
Section 8.14 of the manual should be all you need.
note the ‘+1’ feature on the fn key - very useful for large chunks of assignment.
