Recording to DAW and QU-drive simultaneously
I’ve searches this Forum but couldn’t find anything that would answer my question.
Next month I have to mix a live event that will be released on a DVD. There will be a camera team and I have to provide the multitrack recording (using a QU-24). It is a four piece band (drums, guitar, bass and 3 vocals) so the 18 tracks of the QU-drive will be sufficient.
In the past I have recorded to QU-drive OR DAW (Logic Pro X) depending on how many tracks I have to record. Both worked fine so far.
I know I can record tracks 1-18 with the QU-drive and tracks 19-24 with the DAW (with 18+ tracks I’ve always used the DAW as a stand alone recording solution, though).
But the upcoming event makes me a bit uneasy, because there is quite a lot of money in it with the camera team and all so that I am wondering if it is possible to record the tracks 1-18 simultaneously to QU-drive AND DAW to have a backup recording if one should fail.
The recording time will be 2 hours.
Anybody tried that before?
Cheers from Germany,
Martin
It just works. The first 18 channels output to USB go to both, the remainder go to USB-B only.
Given the limitation you might want to push groups to the lower channels (or at least L&R) even if that doubles up on things in the DAW
I’m doing this regularly with even more tracks from the Qu32. There I use groups to collect “simple” or “not concurrently used” instruments together, which go to the first 18 QuDrive channels, so I still have a complete recording on the QuDrive as well. On the DAW I also record the separate channels so I effectively get two complete recordings, with the QuDrive seen as backup.
Good to know. Thanks Guys!
Yes always record to both if its a serious recording especialy if you are getting paid for it…
I had a situation in an important session recently over 3 days where I simply forgot to push ‘record’ out of the USB-B to Reaper . Luckily I had the QU drive recording so was able to use that.
