Recording to DAW from QU 24
Hi!
Just on my way to get a QU24 and have two questions.
When recording a live session(FOH) to my DAW can I record streaming 24 ch direct after the preamps (I suppose so…) or if I want, with all effects etc included?
I also have some outboard gear that I would like to use if possible. There are no inserts so will this be possible and if so how to do this.
Any thought on this would be appreciated.
/JC
To use outboard gears you need an AUX for Send your signals to the outboard gear and then a normal input (or stereo input) for your FX-Return!
Thanks for the info!
Any thoughts about the DAW recording issue?
Hello. I have just spent about 3 days testing with QU16 and Reaper. And I’m stunned how easy it all works as a DAW! Flawlessly.
QU24 not available for a few months where I live.
Plugged in an ME-1 and that works great with the DAW scenario as well.
I used the USB-B streaming into a macbook pro.
I cant see why you would want to use inserts in a recording like you suggest. The QU has a host of compression types available
I spent a year learning , making templates with Reaper and GSR24M. (firewire)
And this QU just plugs and runs?
Need to install the App though.
Hope this helps
cheers
davyd
Thanks for the response!
Can I use any of my external Preamp passing the once in the board? There is no inserts so is this possible… I do some akoustic recordings live, and usually would like to use some of my own preamps for a few instruments.
/JC
