Recording to or via USB Main
For some reason i cant seem to get the multitrack recording
to record the main
i have tielines from all the channels andf that works fine
i have then set:
under I/O output - mixOUT then under USB main to record on usb 21/22
is that not the correct way ?
And you have changed the USB from SQ-Drive to USB-B to change the port used ?
It wouldnt affect the recording of the master out but im trying to record it onto usb stick but its the same om usb to the PC…
