Recording via madi
i do have idr 48,idr 16,t-112,t80 connected thru allen heath madi card fitted on the mix rack, now i wanna record all the channels and play back into the ilive surface its some thing like a virtual sound check ,i want to record and play back and mix on the surface when the musicians are off stage,i have heard rme is got madi options but does allen heath recom them
Hi Moses
We have tested the RME equipment and have had no problems with this equipment.
I would suggest any of the below:
For laptop Recording
https://www.rme-audio.de/en_products_hdspe_madiface.php
Desktop - PCI
https://www.rme-audio.de/en_products_hdsp_madi.php
Desktop - PCI-Express
https://www.rme-audio.de/en_products_hdspe_madi.php
Hope that helps
Regards
Sam A&H
Hey Sam ,
Thanks for the reply,on the display pic there are two cards should we buy both or just one pci card for computer, one card is got madi i/o and fibre optic out , the other card is got midi and madi card so please let me know about this
Hi Moses
When you buy the HDSP MADI - you get both PCI cards included in the box, fit them both to the PC the main PCI board does the MADI I/O - the second is a mini extender PCI connector board that connects to the Main PCI board. This enables you to have MIDI and Wordclock IN/OUT aswell.
Regards
Sam A&H
is it quiet big process to assign channels to play back and record all the channels for a virtual sound check
Hi Moses
Please read the Understanding MADI guide on our website i have attached a link below. Hopefully this will help you.
https://www.allen-heath.co.uk/dl/iLive%20Series/Application%20Notes/Understanding%20M-MADI%20-%20rev%2015JAN10.pdf
It is relatively simple to setup a record and playback system with iLive as long as you know how to configure the system correctly.
I would suggest configuring 2 scenes 1 for record and 1 for playback.
Record Scene 1
input source = Mixrack inputs, Outputs = PortB - set to either ‘mixrack inputs’ or ‘input direct out’ send to the recording device.
Playback Scene 2
input source = Port B inputs from recorder
Regards
Sam A&H
