Hi guys,
here’s an overview of my system:
SQ5 connected to DT168 over a Dante network. An iMac is also connected to the Dante network via a switch.
I can route audio from the DT168 to Logic X but I can’t seem to route audio from the SQ5, is this possible? Is there a setting I need to change on the SQ5 channel strip?
My Dante Controller shows everything is connected with green ticks but no audio passes to Logic??
and what have you done inside the SQ?
if you send nothing to the Dante Card it will not transmit anything
#morescreenshotsplease
On the SQ you have to route some signals to the dante card outs. Either tie lines, channel direct outs, mix bus outs …
That’s my question, what do I need to do in the SQ and how?
How do I ”tie” Channel 1 to the Main LR AND send it over Dante into Logic?
how about reading the manual first?
or google a bit?
we should not have to explain everything
Routing is done in the SQ on the I/O Screen.
This Matrix is important.
There you decide where the signals go to.
greetings
@steffenr I bet you’re a bundle of laughs at parties! Please don’t comment on any of my posts in future you’re most unhelpful, arrogant and rude.
thank you
did you read the manual?
