Under “Healthy” I have a red cross on my Madiport. What can course this? It´s a Lynx Aurora16 with madi card in it. According to the Lynx it is in Sync but as soon as I connect the Aurora out to the Madi Ilive in, I get the error led on the card in the B-slot and the red cross on the screen.
I have tried changeing the madi card in the Lynx and another Lynx and a firmware update.
My SSL MX4 will lock and stay healthy/happy with my Ilive port.
I´m pretty sure that it is a problem with the Lynx output but any idea what? What will make the Ilive to turn up with a red cross?
This redcross under the healthy link would suggest that you are recieving a digital clock but the clock may not be valid for the iLive. Check to make sure that you are sending a valid audio clock at the correct Sample rate 48K only.
The Lynx is set as slave to the Madiport and the IDR is master. The Lynx locks on to the signal from the IDR at 48 KHz. It is the return signal from the Lynx that the IDR reports error on.
I dont think it´s that. I should be able to use both in and out from the converter with Ilive as master.
Even with Lynx as master and the Ilive only recieving madi it reports error. Ilive can lock on to the signal but it still has got this red cross under madi “healthy”.
What would make the Ilive call a Madi input not Healthy?
I posted your reply to Paul from Lynx and Benum. I have Benum to do a test with a new Aurora and a new IDR with madi. If it turns out to be a problem with a single unit then thats it. If it turns out to be a problem in general - I will let you know.
