Red firmware version cross
Hi all,
Wondering if anyone else is getting a random red X re firmware version? It’s only been happening since 1.82…any ideas on why and/or how to stop it…
TIA
Dave
T112|iDR48+ACEcard|Laptop|iDR16|iPad|iPS10
It’s not random in my case. I have always a red cross at firmware version if I connect my xDR to the system, but everything works flawless.
SRV-AVB
R-72, iDR-16, xDR-16
I noticed it also last weekend. There was suddenly the red cross. Never had it before. Indeed since 1.82
In my case it also seems random.
Like Steffen said, luckily everything works fine.
Rene
Nothing is completly true, and even that’s not true.
Hi Riggs
Do you know what event log message is being created when the red cross appears? and does it flicker on and off randomly?
I would suggest you save a copy of the event logs when the problem occur’s and then send them in an E-mail to A&H technical support. They should be able to diagnose what is causing the problem from the logs.
saving the event logs can be done by inserting a USB into the surface then navigating to Utility menu - diagnostics - event logs - then press the “store all logs to USB” in the top right corner of the screen.
Regards
Sam A&H
I’ve been getting the red cross more offer too. I’m still on 1.8 and the cross appears when I log on with tweak sometimes. When you look at event logs it disappears, and then you know all is good till it pops up again (rare).
J
R72 & IDR32
Hi Sam,
Which email address/where should I send the log file?
No, the red X doesn’t flicker…comes on and stays on…a further thought…if a scene created in a previous version that hasn’t been “store all” or "update"d in the current version is recalled, could that cause a conflict that would result in a red X?
Cheers
Dave
Hi Riggs
Please Contact A&H customer support at: https://www.allen-heath.co.uk/support
Login and submit a helpdesk ticket.
Regards
Sam A&H
Sam, any news on that? Will you inform us?
SRV-AVB
happened to me last night. Then it went away after a little while. I will check the log today and see what it says the next time it happens and report back.
Glen Clark
FOH The Church At Covington
T112/iDR48/PL6
The Church At Covington Front Of House
Red Cross on Firmware was displayed on my console last night. Checking the log today and will also submit to tech support. Version 1.82.
CRJ
Oswego, IL
T112 & iDR48
Sony F 1.73GHZ I7 8 Core
Win 7 Pro 500GB HD 8G RAM
TP-Link WR1043ND
Airport Extreme & Express
Dante May?
when my x came up is when i hooked up the laptop to the network with the incorrect ip address. when i fixed it, the cross went away.
Hi steffenromeiss
Do you only get the red cross when the xDR16 is connected or do you get the Red cross all of the time?
Please include the answer when you Contact A&H customer support at: https://www.allen-heath.com/uk/support/Pages/support.aspx
attach a copy of the event logs and how your system is configured.
Support will then be able to directly support you on this problem.
Regards
Sam A&H
Different system without any xtras has it as well.
iDR48 and T-112
SRV-AVB
Hi Steffenromeiss
There are many reasons why you may get a red cross next to the firmware status.
This does not always mean that something fatal has happened to the system. The iLive system will use this tool to warn the user that an error of some sort has happened. This could be a physical cable issue or a software issue and the reason for the red cross will be logged in the system event log.
Because there are many different triggers for the red cross, it is the event logs that must be used to identify the cause. This is why we suggest you send a copy of the event logs to A&H support, they will then be able to tell you what caused the event log. Please also try and make sure you have correct Time & Date set in your system so we know where to look in the event log.
You can look in the editor help system for an explination of the types of Red cross error or the iLive reference guide part 2 firmware - page 92.
https://www.allen-heath.com/UK/CategoryDocuments/iLive%20Reference%20Part%202%20Firmware%20AP6526-2_5.pdf
This should not have been caused by updating the firmware to 1.82.
Regards
Sam A&H
I was thinking the red cross came from a badly configured MAC bad it does not went away as the MAC was disconected.
For this board we are already in contact with our distributor, because there are some other issues as well.
With my own system I have no issues, only the red cross after connecting the expander… but it works
SRV-AVB
