redo the patch
Is there a way to move the tracks while keeping the data (name, EQ, Gate, …) in order to redo the patch
no
Does Copy & Paste not achieve that?
Or save each one to the library & recall it from there?
OK - To answer myself - The Library works, but C&P seems not to move names or preamp
(I think)
does the library save the name and color?
Yes - options to recall “Preamp”, “Name”, and “Colour” (in offline mode on app anyway)
I just gave it a try, it actually works.
Thank you Markpaman
But i personally would love to see a method like on the Yamaha consoles where you can move a channel, lets say channel 34, to another place, lets say to channel 5, while all channels from 5 to 33 move one slot to the right. Same feature I would like to see on the dLive.
Sure, you can rearrange the channel strips on the layers, but nevertheless the pathing and input channels are horrible scrambled in the worst case. And it is for sure not helpful when you always have to remember that the channel on the strip numer 5 is in fact input channel 31 and the input socket is 46.
In the ideal world everything would be clear before you come to the show. But who of us did not have to deal with incorrect rider or surprising special guest or extra instruments?
Hey Mfk0815,
atm we can rearrange channels within a specific faderlayer. But you are right. I could be cool to grab an input channel in the strip assign menue and drop it anywhere. But it might also be a big source for confusion…And it probably messes with the A&H faderlayer concept…
Cheers
Mfk0815,
on which Yamaha console can you do this?
As all channel strips can be assigned anywhere, I feel it actually helps to not also be able to change the order of input channels – just for the sake of staying sane ?
as far as I remember on M7CL, QL, CL and Rivage
but rearranging channels introduces a short break in audio
and it’s not possible on DM and PM
TF, LS-9 and O2-R I don’t know
Having learned everything on the job, I usually prepare my patch before the concert by bringing together voices, guitars, drummers … suddenly if a new singer appears I have to shift everything! I may not be using the correct method?
as far as I remember on M7CL, QL, CL and Rivage but rearranging channels introduces a short break in audio
Hey Steffen,
to my knowledge, it is not possible to change the order of input channels on these desks. In fact, that fixed architecture seems to be one of the advantages of the Yamaha boards.
However, QL, CL, Rivage and even LS9 have user layers which can be populated in any way the user choses.
I recognize the behaviour you are describing (inserting a channel causes a drop out) from the Avid Venue consoles. I believe on these desks, all following channels will indeed “move to the right” in this case. However, the patch does not change.
https://youtu.be/vQ9yv7xGNNM?t=448
Channel job
Cool, I have never used that feature.
I guess that was really useful on a PM5 or M7.
However, it doesn’t “redo the patch” - which I think is a good thing.
I like to keep the original patch, add any extra channels to the end and then (re)arrange the channel strips in a way that makes sense. But that’s just me.
