Hello,
My set up is IDR-32 fixed FOH and IDR-10 Monitors. My FOH Surface is a 144 and my communication protocol is ACE (Monitors controlled via editor). For some reason it appears that redundant link is enabled. I cannot tunnel channels above 32 from the Monitor console to FOH and in the ACE Link output tab it shows “Warning-Redundant Link Currently Enabled” Anyone have any ideas to get around this?
Jason
M. Jason Pruzin
Sound Designer/Engineer
Arkansas Repertory Theatre
To follow up I finally just recalled a show that pre-dates any attempts at using iLive’s templates. Something seems to be wonky in the templates as they have caused me to lose the PAFL and now screwed up my dual mic splits. Users be warned that if you have a system that functions as you like I recommend just taking the hassle of reseting from there instead of trying the templates until A&H can look at them.
M. Jason Pruzin
Ok this is really strange, but I think I’ve finally sorted this out. In a FOH/Monitor split system it appears that the redundant links need to be “on” at both Port A and Port B of the slave (FOH) system to tunnel the Master’s (Monitor) inputs above 32 and for the PAFL headphone out to work. Maybe it’s not so much strange, but I believe this is a change from a previous firmware version where for tunneling the redundant link needed to be off. Sorry to confuse the issue and take up bandwidth-hopefully this will help out someone like me that has been a user for a while and got twisted around a little through the combination of steady upgrades along with my own constant re-configurations.
M. Jason Pruzin
