Remote fader bank for Stream output
We are using an SQ6 with one of the AUX outputs for a live stream (church application) which is then sent to VMix for the stream. In the stream suite, the operator uses an iPad with the SQ6 software to mix the stream independently of the house. Instead of the iPad we would like to use some type of fader bank (about 16-20 channels) to mix the stream instead of the iPad. Anyone have any experience or insight on doing this without a Dante card or a DAW?
-jeremy
The easiest might be to use a combination of the Mixing Station app and a midi controller of your choice.
https://dev-core.org/ms-docs/midi/
…or an SQ5 and an SLink card for ultimate control.
Any way you cut it an ancillary streaming mix works far better with tie lines “post pre” to a DAW. A competitive streaming mix has a much higher bar of acceptance to hurdle than any house SR can realistically accommodate.
Hugh
