Remote Operation
Please consider creating the ability to connect the CQ wifi to a local wifi hotspot near the mixer and allow a user to connect, connected to their own remote wifi to sign in and operate the mixer from a remote location over the net.
I’m operating for a Church where I’m currently unable to physically attend and mix. This would allow me to monitor alt outputs via livestream and mix those sends in real time.
The mains are working perfectly, setup to work without touching anything - completely automatic within a fixed/static acoustic environment…
Thanks for reading and considering!
All CQ have Ethernet to achieve this. And the CQ-12 has no WiFi.
All requirements for this kind of functionality are on the side of the network admin.
To enable something like that inside a mixing desk and without further knowledge would be a security issue in many environments. And many routers and firewalls will block it anyway.
The network admin will have the responsibility to do the right things to secure the connection.
That will not be in real time.
Live streams usually delay the audio by some seconds.
thanks, I really appreciate your response and thoughts -
it’s CQ20B
Real time was used loosely - a few seconds or even minutes is far better than listening the next day and guessing what needs to be done. Then, I have to wait a week for the next livestream to see if the changes were correct.
Are you saying that if the CQ is connected via Ethernet, the mixpad software will be able to connect via the mixer’s local broadband IP addy? The only option I see to connect is the CQ’s wifi (or demo) -
I’ve become disabled but remain responsible for the entire sound system I built upon the CQ.
I’m also a network admin… The broadband modem/router at church is using entirely factory default settings. I understand the security issues, thanks.
Could this be accomplished with mixingstation web?
I haven’t used the web version, just the original app version so I can use an X touch control surface to have a tactile controller with motorized faders. I could be misunderstanding what is trying to be accomplished but that would be something I would consider looking into if I needed some sort of extended remote controlling functionality. Since it’s a web/cloud service, it’s subscription model.
No. That is not what I said. But if you use a VPN you can connect.
VPN on which end? And, how will the mixpad software recognize the remote mixer to connect?
OK, I just found “Connect using an external router or network” instructions to directly connect the mixer and router. VPN is not mentioned? I will try this as soon as I’m able to go there and hook up the Ethernet.
Are you really a network admin?
That is not recommended. It is not secure to do that.
why thank you, Sir - yes ever since novell, and SCO Xenix…
