Remote playback into Qu
Is it possible to input audio say from an IPHONE or Android to a QU-32 by Bluetooth? Maybe with a USB Bluetooth installed? If not any other suggestions to play audio remotely into a QU-32?
There are numerous BlueTooth receivers that you could plug into your QU - I have a very small one which sometimes goes into the 3.5mm jack if needed.
Mostly though, as I use an Apple router, I stream music over AirPlay to that & use an analogue cable from router to desk.
Thanks for the info. I found a bluetooth receiver for mixers: Alto Professional Bluetooth Total. It might be a little overboard if a simple USB bluetooth will work.
I doubt a USB - Bluetooth device will work. Qu-Drive is looking for a for a memory disk that it’s formatted itself, and files in the exact format it can recognise.
Ok; I see the QU-32 has a 3.5 jack, so this type of bluetooth will sync a smartphone to mixer to play audio from smartphone?
