Select the mixes on e right (activates sends on faders), one of the buttons level with the select strip is marked sel - holding it shows what channels are enabled on the current mix.
ā¦or simply mute Fx when feedback happensā¦
ā¦you still didnāt told us, how your feedback sounds like. If youāve implemented some loop in your Fx settings, that really would sound pretty nasty and would occur regardless of whats happening on stage. I think youāre looking at the wrong place hereā¦
Select the mixes on e right (activates sends on faders), one of the buttons level with the select strip is marked sel ā holding it shows what channels are enabled on the current mix.Do you mean the "Assign" button? I cant see this extra SEL button only my usual Green Sel buttons per channel and LR Master.
Yes, assign. I donāt have a QU in front of meā¦
Dick,
You make some good points, however, your experience appears to be limited. Iāve only been doing this for 50 years or so, and I havenāt been in every possible situation, but I tend to make good observations. My comments made it clear that I wasnāt trying to write the book that could be written on this topic, but I could write that book. I was simply trying to point out the issues that needed to be considered, not cover every aspect, and my experience has proven that all the factors I mentioned are indeed pertinent, including the fact that different vocalists can generate different feedback.
My doctorate is in chemical physics, so I understand physics fairly well. Feedback will not occur at a frequency that is not generated in the room in some manner - thatās simple physics. A GEQ is better for eliminating feedback for several reasons, but Iāll just name a couple. Generally, a GEQ will have narrower Q at each frequency, so it can be used to remove feedback, which tends to be a specific frequencies, without unduly affecting overall sound. A true PEQ, where one can narrow or widen the Q is great, but there are usually only three or four of these for a given channel. Most GEQs have 28 to 31 bands, so more feedback frequencies can be tuned out. The more bands one has on a GEQ, the narrower the Q. If you are lucky enough to have a fully parametric 31-band GEQ, then youāre in good shape. Most inexpensive digital mixers donāt have these, as you pointed out.
You seemed to have a problem with what I said about condenser mics. Apparently, you just havenāt used any good condenser mics. Possibly all you know about are SM58s. The low- and high-frequency response of condensers is significantly greater than dynamic mics, and their transducers are much more sensitive, so a different type and amount of EQ is needed, at least that has been my experience. Maybe you just need to compare the frequency response curves of different mics - you do know what Iām talking about, right?
You said, āAgain, this is sort of OK, but the statement is rather rigid and many clarifications need to be made to to situational variables.ā I stated āIām assuming you know the factors that you need to consider with each of these.ā My statement is only rigid if you assume it is. I was just suggesting one possible procedure that has worked for me many times, but what one needs to do is dependent on the situation at hand. It is not feasible in a forum like this to cover every aspect of every possible situation.
You seem to be good at picking fights. You chose not to read my comments carefully and misinterpreted several of them. I donāt feel it is necessary to point out all of the instances. I just chose a few. I noticed that you failed to offer any advice before I made my comments ā why was that, if youāre so knowledgeable? Why donāt you go ahead and give us the procedures one should follow and provide all the clarifications needed? Iād like the opportunity to critique your recommendations. And BTW, there is a 1024 KB maximum file size for our comments, I think. I doubt that youāll exceed it.
Hey, no need to make a personal fight out of this!
We all have our own experiences and methods to operate some live situation, particular feedback.
I personally never had any musician on stage who causes a feedback problem, it always was some mic/gain/speaker issue. Except the guitarist with eye glassesā¦
For my opinion we still do not yet pinpoint out the cause of the feedback of the OP.
We still didnāt get the information how it sounds to determine, if it is coming from the room or suboptimal PA placement.
Talking about feedback from monitors isnāt helpful at all, since it was stated quite early that the band already uses IEMs.
Talking about some high end GEQ with all bands full parametric (that would be a PEQ, btw.) does not help either, since the GEQ inside the Qu does not offer that functionality and effectively does affect more than just the critical frequency.
But since Iām more on Dickās side while reading your post, my experience obviously is quite limited as well. I can live with that.
ā¦two weeks ago you stated āFirst, let me be clear that I do not have an A&H consoleā, did that change?
Hi
A little update. Firstly thanks for all your advise.
I had the opportunity to play in a very small pub at the weekend with my three piece rock band where I only needed to put vocals through the PA.
I didnt have much time but I rang the room out quickly with the vocal mics finding and dropping the problem frequency on each channels PEQ with as narrow a point as possible.
It worked a treat and I managed to have the vocals nice and high in the room.
Iām sure I couldve rang it out again to find more slightly less problematic frequencies but for the pub it was fine.
The only issue I did experience with feedback was when I left the system on unmuted by error when I walked away from it and it just about managed to start to feedback after a while.
God knows why though.
Docā¦
I started out in the late 1950ās by making my own microphones from telephone equipment and my own amplifiers out of old radios. Since then Iāve made my living as a musician and technician doing performing, live audio, recording, broadcast audio and audio for camera video shoots. I havenāt read your entire reply yet, but the first sentence was enough for a reply.
No one can argue with another persons experience, but in communicating this in your initial post youāve put in some erroneous info and some popular audio misconceptions as fact. I always correct those statements, disagreeing with the inaccuracies themselves, not the person stating them. Iām sure youāre a fine old fellow a few years younger than myself, but Iāve been doing this professionally for nearly all my life and do know whereof I speak.
DR
Dr. G and Dick:
Keep the conversation rolling! I, for one, am enjoying it immensely. Iāll read what you both have to say, then take from it what I want and incorporate it into my own sound reinforcement cognitive schema.
@coffee_king: Am I right that you do not intend to disclose further information on your stage/PA layout and/or how the feedback sounds? Making it somewhat hard to provide useful hints.
Sure, if youāre in a very small room with hard walls controlling feedback from the PA may indeed be an issue, but decreasing the overall volume would be a possible cure as well.
I still believe youāre trying to deal with symptoms not the problem. While this may work more or less, this is the hard road to go.
And if the particular feedback indeed originates from a room resonance, why not adjusting the single PEQ in the mains instead of every mic channel?
If its not a room resonance but a high pitched direct feedback from PA to mic, then PEQ probably does not help much if the microphone can move around the stage. Changing the mic location will result in different feedback frequencies. Turning down the volume (reducing compression, if used at all. Didnāt told us that either) is your only option.
Or, in other words: If you face similar problems in any room you are performing, its likely not a room problemā¦
Please write a list of anything you want to know and Iāll gladly advise.
Ive posted Showfiles on other posts but no one has responded to them.
Only three points:
- How does your feedback sound? (High or low pitch)
- Where is your PA located in relation to your mics?
- Do you have any gates or compressors on mics?
ā¦I saw the showfiles, but I didnāt had time yet to go through themā¦
Never high pitched.
Speakers always in front of mics - Iām not completely stupid ![]()
As of yesterday I completely reset every channels EQ to flat (apart from a hpf). No gates. No compressors (although I will start to use again shorlty). Also now only using one FX which is a reverb.
Thanks, now we can work on it⦠![]()
Never high pitched.Ok, room resonance, period. Any idea about the frequency range? Maybe pitching the HPFs little higher would help.
Speakers always in front of mics ā Iām not completely stupidsure, but you can't imagine what I had seen in my life... ;-)
Think youāre on the right direction. Not sure if reducing the overall volume is an option for your band, but in smaller rooms you should think about that as well.
And if youāre using multiple mics try to find out if one of them is dominant in generating feedback. Using different type may help⦠But thatās getting pretty specific nowā¦
90% of rooms will have problems between 160-400. I usually start by pulling that range. 200-250 is culprit in just about every room. Then it moves up an octave.
CKā¦
I have a PDF about dealing with room resonances/standing waves. You are welcome to it. Just PM me a valid e-mail address and Iāll send it to you.
DR
(pay no attention to the man behind the curtainā¦)
Just post the link to the PDF
so āeveryone can read itā
Iām sure a lot of ātechsā out there are watching reading this forum.
The PDF link would help other newbies
Just post the link to the PDF so āeveryone can read itā Iām sure a lot of ātechsā out there are watching reading this forum. The PDF link would help other newbies
Sorry, I do not have a website. Iāll be happy to send it to anyone who requests it. To date I have probably sent it out to several hundred folk. It may have helped some of themā¦
Drop Box?
If its not too big post it on here?
āSound isā such a āpersonal and controversial subjectā
Hi
PM it me please and Iāll host it on here for everyone to access.
This is one of my major gripes with this very basic Forum. No file/image hosting etc included for free.
Its all very late 1990s.
You can only just about quote previous posts. ![]()
