I’m at wits end…don’t know if I have a gremlin in the brand new board or if I’m just dense.
QU-32 worked perfectly fine first four gigs. Now Mix 1, which was simply a single vocal (Channel 18) and guitar (channel 11), is getting pounded with the Kick drum from Channel 1. Press the MIX1 button & only two channels pop up…11 & 18. The only way to get it out of the mix was to mute Channel 1. Obviously not an option.
I’m running 5 mixes. Only Mix1 is having this issue. When I switch to Mix7-8 (just using the left out), with the same two channels, it works fine.
Is there a pre-fader setting somewhere that could be getting into this mix? Where else can I look? Running Version 7.1 that came installed on the board.
I run everything directly into the board…the board is set up on stage, so I’m not using a dSnake.
As I started writing about this I realized the first question everyone will ask is “has anything else changed?”. I should have thought of this at the gigs this weekend, but I was using the Qu-Pad for the first time live. Has anyone experienced this kind of problem? It is a brand new iPad (I really hate Apple…so proprietary), and the Qu-pad version is also 7.1.
If I had thought of this at the show I could have turned off the router and disconnected the iPad to see if the problem went away, but it was crunch time & I went with the workaround to get through the show. But, like I said, when I went to the board to check the mix, only two channels came up. No idea where the kick on Channel 1 was coming from. It was not bleeding in from the vocal mic…I turned both of them off…the board faders were totally flat, (except the master), and the Kick was still there.
Any thoughts?
TIA!
