I want to simply route the L/R to any of the outputs (1-6)
I want to buy the CQ-18T but the lack of this feature is making me look at other mixers. I currently have an analog mixer that has a 4 Main Out( 2 XLR and 2 jack 6.3) and I use 3 of those for the sound system in my church. It is such so simple to have 1 fader for those 3 outputs. It simple to explain to volunteers also.
You could create a DCA with the three output channels. Then you can change the (relative) volume of each by the DCA fader.
But also note that the outputs of the are symmetric (balanced) TRS
Can’t you already do that using the Config - Digital tab - and select under the Main Outs or USB bus the routing?
Cheers
David
