Hi
Is there an easy way to route the Main Mix to a Stereo Mix like 9 to have the exact same sound on stage while still having the possibility to use EQ for monitor mix?
I want to control the Main mix on stage which is no Problem though we dont have drums.
Thx
Bernhard
To have exactly the same sound why not just use the alt outs?
Never convinced that feeding FOH across the stage is a good plan, but it might be the least of all evils.
You could set mix 9+10 as post fade & set all the sends a unity.
If you have a 24, 32 or Pac, you could use a matrix out - or route everything to a subgroup if you’re not already using them.
