I’ve just bought a D-Link DIR510L to use with a QU-PAC.
https://www.dlink.com/uk/en/home-solutions/work/personal-hotspots/dir-510l-wi-fi-ac750-portable-router-and-charger
The router has connected to the iPad easily but when I load the QU-PAD app my QU-PAC is not showing up!? It D-Link doesn’t appear to be connecting to the router?
Any ideas what the issue is?
Looks like it’s a pure router without any lan ports…
So it won’t work, no.
Can you drop it into access point mode, or bridge mode?
EDIT - just looked and it doesn’t look like it has an appropriate mode - sorry
The QU-PAC must connect to a wireless router via an ethernet cable plugged into a LAN port on the router. The DIR510L has no such port, so it will not work. Something such as a D-Link DIR-813 AC750 Wi-Fi Router is what you need.
See the QU-PAC manual for how to set up the mixer IP address.
