Routing a mix to AES output
I’m using the qu-16 and I’m trying to get mix 3 routed to the AES output, but I’m having problems. What are the steps involved to make this happen?
Using QU-Mix go to the top option “IOPatch”
Press then select “Surface” from the tabs on the LHS.
You’ll see “AES Out” on the second column., spin it until you get “Mix 3”
Sorted!
