Does anyone know if the following is possible?
Thanks in advance for any information.
I want to route external effects from outputs 1-6 and back into a regular input (1-18) and then into the main output.
Example:
Channel 1 IN > routed to Output 1 (separated from the main output!!!)
Output 1 > signal goes to EXTERNAL effects
- Effect > goes back to one of the regular inputs (e.g., Channel 18)
- Channel 18 rout to the main output as normal
This would give me the option of using all 6 outputs separately as monitor OR extern effects sends! to use the main output. - The CQ 18T has enough inputs to use some as a dedicated external effects chain and THEN route them to the main output.
- The important thing here is that you can route each input to one or more of the six outputs without main output and / or ! it also being routed to the main output.
It’s possible ?
Thanks in advance
Greets HP
