Routing problem?
I’m new here, but I have a interesting question for you fellow users.
I own a iLive T112 with a iDR48 rack.
Today I was running through some older shows and something strange happened. The fader controlling Mono Aux 3 also moved the fader for Stereo FX send 1. When I sent an input to Mono Aux 3 it didn’t share the Mix, but it was sharing the fader and Mute button, almost like a Gang.
I’m running version 1.80, will be updating to 1.81 tomorrow, maybe it will fix it.
The strange thing was that I loaded an original show and scene from the library, and it was ok, but after changing some options (post to pre on the Aux’s) there it was again, the same issue.
Has this happened to anyone here? If so how did you fix it?
Thanks in advance for your patience and input.
Rui from Lisbon
Surface: T112
Rack: iDR48
PC: Editor 1.81
iPad: MixPad
Hi Rui
Please update to v1.81 and see if the problem persists. If the problem returns please contact A&H technical support with a detailed description of the problem and a reproduce procedure if possible along with a copy of the event logs.
https://www.allen-heath.com/support
Regards
Sam A&H
Today I restarted the console, and tested it before upgrading. It was working fine!?!
At least for the time it took me to recall some of the older memories. I then proceeded to install 1.81 and continued without any problems.
If something similar happens again I’ll do as you suggested, thank you anyway for your reply. I hope I won’t need anything else again.
Rui
Surface: T112
Rack: iDR48
PC: Editor 1.81
iPad: MixPad
