Thanks Dick. I find your posts both informative and engaging. I’ve only been doing this for just under a year (around 20 gigs under my belt) and it’s a steep learning curve. Some of the little tricks and tips you pick up on here (your delay tip for example) are priceless.
Roy
@ Dick Rees and the ‘pitch pipe:’ Thank you! Thank you! Thank you!
I am just a retired guy who started hosting karaoke at several local venues. I’ve Googled over and over and yours is the first cogent lifting of the feedback veil for the ignorati. Much appreciated … and my singers will thank you too!
Same trick for my subs on mix1, between 2 and 3ms for a 200 peoples gig.
Try it and venues takes some presence.
Also for an instrument, put it 20ms before all others
and it get louder without touching any faders.
