the RTA’s on mixpad will not change to different aux’s unless I go to the board and change mixes. When I change mixes on mixpad it will say the RTA is coming from the last channel I had up. This is not very handy seeing as the mixpad is mostly used to set aux’s for monitors and I don’t want to walk all the way back to the board to reset the RTA for each channel.
Set the RTA to follow the PAFL selection, then hit PAFL on the mix you want to
look at.
