Hello! I recently purchased the 20B and was surprised (and disappointed) to learn that only two CQ Mix apps can be used simultaneously while running the mixer. I know that most people will say that I should have seen that when researching before purchase, but given that I have never owned a digital mixer that had that limitation, it wasn’t even on my radar. Would it have been a deal breaker prior to buying the mixer? Maybe. Already bummed that there is no way to provide additional sub mixes past six (which I knew about prior to purchase), but with this new information, definitely feeling a bit of buyer’s remorse. Any chance that this could be remedied in the future, and also…why have this limitation in the first place? Thanks!
Hi, so I’ve worked with CQ’s quite a bit. Yes, it does only allow for 2 Mixpad connections however, with those 2 connections you also get 6 CQ4U connections.
Hope this helps.
I would look at it this way: ideally, only one person should be responsible for the sound - as the saying goes, “Too many cooks spoil the broth.”
Especially with small setups like those using the CQ, it’s also quite rare to employ the kind of structure seen in musical theater, where one person might mix the vocalists while another handles the band.
Then again, perhaps you have something very specific in mind - who knows … ?
A&H once indicated that this limitation is necessary to ensure sufficient bandwidth for reliable control and the transmission of the meter datas.
Furthermore, in typical use cases, it’s quite common for up to six musicians - in addition to the two users running the CQ MixPad app - to want to control their own monitor mixes via the CQ4You app.
And with a total of eight connected devices, you reach a level of capability that actually matches that of even the higher models in the QU and SQ series.
Thanks for the response, and it is nice to have dedicated apps that don’t allow members to do too much “mix damage”, if you will… ![]()
Thanks for the response! While I agree that all your points are valid, in our case we have several members that are pretty well versed in spot checking front of house mixes, and handling sound issues when they arise (we don’t have a sound person, so it is reliant on a few members). Each person has their own iPad, so we need to switch iPads between players. A crisis? No, and certainly workable, but a bit of an inconvenience. Also, while the CQ4You app allows users to set their monitor levels for each channel, that is all they can do. They cannot set effects on their monitor, adjust compression, EQ, etc. As someone that likes to do that, it is a bit annoying to have to be playing “pass the iPad” to make it happen.
Overall, not a big deal. Just mentioned b/c coming from the Midas MR18 where that wasn’t an issue, I was a bit surprised to see that limitation, and would love to see that addressed, but I don’t think that will be coming anytime soon. Thanks again!
Hi, glad my last message helped.
Just looked into it and even I find it weird that CQ don’t have the ability for EQ and dynamics however, you can still add the effects. The musicians just have to add them in under the groups section in CQ4U where they’d put different mics and instruments.
Ah, I see…I didn’t dig that far into that app, but something is better than nothing!
Thanks again!
