S7000 un-linking stereo issues
Hey Guys. So something of interest is when you unlink a pair of inputs that have been stereo’d, if you have sent levels to fold back for example as PRE or any other routing, this resets everything upon linking or unlinking.
Muting is also affected and if you run a LR matrix send into Sub etc it will add it back into all matrix.
We tried to find a setup option to select weather or not we wanted this to happen. Couldn’t find anything.
We’ve got around this by using ganging and keeping pan out of it.
Would be cool if the desk asks what we want to choose during unlink and link.
Cheers
Dan
AFAIK, there isn’t a great workaround unless you have spare gangs (I usually don’t).
If there’s one critique I have of A&H’s workflow it’s that it assumes you won’t have to change the configuration after you start setting up anything else.
Same reasons I don’t use stereo inputs for general channel lists that would change on a daily, or per band basis. I just use ganging, and almost everyone has zero issue unless they are running a lot of channels and want to save space. I just have a few set up for regular use on walk in music and the like.
Though I did start setting up about 10 stereo channels towards the end of my input list that I can just drag and drop to whatever layer and change the associated preamp socket on them if I, or a touring engineer really need the channel to be stereo.
Yes, that’s a big flaw. Why don’t the two mono channels just keep the routing? Or an option? Also in Scenes stuff is unblocked then iirc.
Me: “How much of a pita can unlinking a stereo channel be?”
Allen & Heath: “YES!!!”
So I unlinked a stereo channel. Then
  • Processing is gone. WTF?
  • Routing is gone. WTF?
  • The second channel is unblocked in global filters and every single scene filter. WTAF?!
I have to now
  • Unlock each scene one by one by hand. No possibility to do that for multiple scenes. Why would anyone want that, doing it one by one is fantastic!
  • Going into each scene filter one by one, because not all filters are the same, and block this channel again. No possibility to do that for multiple scene filters via a scene filter update. Why would anyone want that, doing it one by one is fantastic!
  • On the way adjusting hundreds of scenes you definitely won’t make a mistake. Because humans never make mistakes. It will all be fine!
  • Then you have to lock each scene again one by one by hand. No possibility to do that for multiple scenes. Why would anyone want that, doing it one by one is fantastic!
I mean, who invents such a system and more who are the guys that gave green light to it? It’s an absolute nightmare to work with.
Copy/paste a scene? Not with name and filter, because why would anyone want that? Copy/paste multiple scenes? Not possible, why would anyone want to copy/paste multiple scenes, that would be crazy, noone does that!
